Running lean wouldn't cause it to backfire through the throttle body, sounds like the timing is out.
If you slowly push the pedal all the way to the floor does it behave?
Paul
Hi All
I've just picked up a cheap 1.8L Cordoba for my brother but it has a small issue in that it starts and runs fine but if you give it a boot load of throttle (as in full throttle) it bogs down and back fires through the throttle body.
I've only just picked it up and swapped the fuel pump and installed a new battery and a part from getting it running I've not yet had time to fully diagnose the problem.
I'm thinking it could be a lean fuelling issue (vacuum leak?) or bad ignition timing.
As I don't (yet) have an OBD error code scanner I can't check for error codes - any suggestions would be greatly appreciated.
Chris
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Pull the electric carby off, and inspect the rubber gasket between it and the intake manifold.
They have a habbit of perishing and causing all sorts of weird running problems.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Even just moving it about at idle would prove the rubber mount.
Thanks for your suggestions all, when I slowly open the throttle it has a slight cough at around 2000 rpm but it will recover and run past this point all the way to red line if required.
My thinking is leaning towards ignition issue but I will check the throttle bdy mount as part of the process.
Thanks again for suggestions.
I have seen a few old 8V engines have the rotor button crack and start making some interesting dynamic timing changes :-P. Have a look in the dizzy first.![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Yeah, pretty much.
Cap, button, leads and plugs are the 'running problems' basics on the 8-valvers.
'01 Beetle 2.0
Check the timing and get yourself a new coilpack. Even if its not causing the issue you will want one in the glovebox for when it leaves you stranded on the side of the road in the middle of the night.
