Results 1 to 6 of 6
Thread: SEAT Cordoba brake pads
    Feb 2007
    Mount Evelyn
    G'day,
    I have just measured size of my brake discs and the size is different to what is specified...
    cordoba normally has 239mm, 35mm, 12mm
    mine has had an upgrade to 250mm,38-40mm, 18mm
    I was just wondering what type of brake pad fits this as the DB400's do not fit as the brake pad if too thick....
    Any help/advice would be appreciated
    Camden, Sydney
    Sounds like they are Golf 3 Brakes.
    Are they vented or solid rotors??
    They may be DB399s.
    Quote Originally Posted by Haganstar View Post
    G'day,
    Hi mate,
    Where does it say that 239mm is what's specified for the Cordoba? I've got 239, 256 and 280mm all listed to suit Cordoba. If yours is the 256mm one then it should be either 0134.50:
    http://www.remsa.com/catalogo/verimagen.php?ref=134.50
    or 0609.20:
    http://www.remsa.com/catalogo/verimagen.php?ref=609.20
    Two fairly distinct pads. In an OEM type performance (Remsa) pad they're $99 and $109 per set respectively, or in a budget street option (RDA) they're $35 per set respectively.
    Regards,
    Greg
    GSL RallySport 1300 884 836
    Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
    QFM Performance Pads
    Feb 2007
    Mount Evelyn
    They may be DB399s.
    They are vented rotors
    Feb 2007
    Mount Evelyn
    Quote Originally Posted by gslrallysport View Post
    Hi mate,
    or 0609.20:
    Regards,
    Greg
    They are the or 0609.20:shape
    Mar 2010
    south australia
    thats the one
