Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: My SEAT GTI 2.0 16v 1999
    Quote Originally Posted by Redgti16v View Post
    so this bolt here I believe.. What is the chances of finding a replacement bolt for my missing bolt..... When I bought the car it came with the replacement belt how can I be sure its the correct belt?
    Sent from my SM-G900I using Tapatalk
    Nah, bottom right of your picture.
    You can't be sure about the belt, except by taking the old one off and trying it.
    The other bolt you can get from a wreckers off a MK3.
    Apr 2014
    Ridgehaven South Australia
    Okay got it.... just cleaned up around the bolt to see what I am doing I have noticed some of the teeth have been chewed up......Half the bolt is still good. I have tried to adjust with the good teeth but didnt budge. I dont want to destroy anymore of the teeth
    Dec 2012
    Sutherland Shire, Sydney
    Use a file to clean up any burred corners
    Try an impact socket (they are the black ones)
    They only have 6 six sides and hug the head very tightly
    Otherwise you're in a spot of bother for sure
    When you get the belt off, compare it's size to the replacement
    Apr 2014
    After abit of research I think I have to undo the belt tensioner so there is more play in this other belt. I dont think I should have to apply that much force make it move. I really have no idea..... someone must have done this before surely
    Dec 2012
    That red arrow is in the wrong place
    The bright silver two part bolt at the bottom right is what you need to focus on
    Apr 2014
    Yep I realize that lol. Im gonna try again tomorrow.
    Apr 2014
    Tried this morning. Worked first time didnt do much different just back of the hinge bolt abit. Turned the adjuster bolt and it moved that simple lol. Thanks for the help
    Apr 2014
    Car wash then a drive thru the adelaide hills...Nice winding roads makes for a fun drive.
