Results 1 to 4 of 4
Thread: My Cordoba wont go
    Bendigo , victoria
    My Cordoba wont go
    Hi,
    My cordoba broke down on the way home today and I'm not sure whats wrong ,
    When i try to start it , there is a spark coming from the lead going into the distributor, and its not starting.
    It did die on me a couple of weeks ago after i went thru some water which was only like alarge puddle during some heavy rain,
    As you can tell I'm not very good with at finding this out for myself so I need some help !!!!
    griffo.
    Aug 2007
    Air, fuel and spark at the right time and it will go. You mention spark which you should have at the spark plugs too, so you have it at the dis, check if you have it at the spark lead too, there is only 2 other things in thats in that food chain. Then of course what i mention above air fuel and spark at the right time and off she will go
    Jmac
    Alba European
    Jan 2006
    Lowood Qld
    from my experience if the eng bay is wet the main prob often is around the coil
    the coil could also be failing...breaking dwn... dying
    i made sure the lead from it to dissie is not touching anywhere else all the way down
    keep a can of water repellant or wd40 handy..if wet; spray generously
    also check any water that may have ventured into the dissie from that puddle ...clean & dry the cap underside also well
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Bendigo , victoria
    Back from Holidays and the cordoba still has,nt been fixed,
    I bought a new set of plugs and put htem in and away she went ,
    Probably needs a service ( Duh )
    Can anyone help with some good advice on whats required to do a basic service ?
    Plugs , Leads , Oil , Oil filter , what else ??
    And wheres the best place to ( and cheapset ) get some leads from ?
    Any Help would be great ,
    Griffo
