Results 1 to 10 of 17
Thread: The little Seat Ibiza CLX
    Dec 2006
    Talking The little Seat Ibiza CLX
    Hi All,
    Probably thought it was better I had a single thread to refer to the Ibiza I've got to go through any issues and a "build" (if you call it that LOL).
    I bought this little beast last year and it's been going good for the trips to work and an occasional Central Coast run!
    Plans:
    1. Brakes (front & rear)
    2. Suspension (shocks & springs)
    3. Wheels (nicer 14s)
    4. New clutch
    5. Timing belt
    I'm not planning to respray it or anything like chucking a VR6 in - I've got the GTI to play with. If I can do it on a budget it should be OK as I'll be working on it myself unless I don't have the tools ! I'm hoping the missus will enjoy
    At this point of time I'm in the process of doing the brakes (it's got drums in the back LOL). The front pads are cactus but never dealing with drum brakes before is going to be interesting. Bloody rain has put it off another weekend
    The only problems I've had:
    The exhaust snapped from the cat back LOL. Sounded like a Mack truck ? YES. Camden GTI to the rescue? YES !
    Some sort of ignition problem. Oh and the fuel was dirty as. So I will need to pull the tank out and give it a good clean !
    I'll catch you guys around (half an hour after you get there LOL)
    -DIDZ
    Camden, Sydney
    Cordoba or Golf 3 Brakes on the front. Cheap and easy upgrade.
    Cordoba or Golf 3 CL drums on the rear is a nice upgrade.
    Timing Belt is not too hard, it runs the waterpump, so you should do that at the same time.
    Clutches for the 1.4 are expensive compared to the value of the car, get an O/S one if you are not in a hurry.
    "The mighty 1.4 Ibiza, its not fast, but its reliable and you can park it anywhere "
    Dec 2006
    Quick update:
    Went to have a look at the rears and there isn't too much left.. but will be fine for a little longer.
    The fronts are rooted literally. I'll get a photo up of what was left !
    My only problem is that the pads that I bought for the car were different to what was on the bloody car !
    So the car is still on stands, need to get them sometime during the week to do on the weekend as braking is becoming suicidal.
    I was looking at replacement cost for shocks for an indicator, almost had a heart attack ! I would have thought you could pick up you Generic Monroe shocks by themselves for fairly cheap. I guess not.
    -DIDZ
    Dec 2006
    Thought I might update this thread.
    Finally got the right front pads and replaced them right at the end of sunlight on sunday. The difference was immediate.
    I found out the bushes and shocks are absolutely rat*****. The control arms just flopped to the floor. A bit of swearing and a brick holding it up I was able to replace the pads and put the wheels on.
    Got quoted for front struts $360 / pair supply. LOL!
    It cost me less to get Koni adjustables for my NX Coupe !
    Will post pad shots when I get home.
    -DIDZ
    Camden, Sydney
    Glad to hear of the update mate, glad you got it sorted.
    We have found that slightly tired GTI shocks and springs are a good upgrade for the 1.4 ones at a budget price
    Dec 2006
    Hrmm Mattt that sounds alright.
    However I have something else to contend with. The wiring for the lights have become pretty fun. Parker lights work, high beam works, driving lights don't. But get this, when I hit the brakes, the passenger parker light starts up !!!!!
    Driving lights were working giving the switch a bit of violence, but not any more. Strictly day driving in the Seat for the forseeable future...
    -DIDZ
    Camden, Sydney
    Could be the switch mate, I have seen 5 broken ones in the last week.
    If you swing past you can try a test unit.
    Dec 2006
    Front driving lights are rooted /electrical
    Hi All,
    Just an update - my front parkers work but my normal driving lights don't !
    The funny thing is, when I've got my parkers on the rear brake lights go on also
    I'm wondering whether it's a relay that's rooted (and if there is a diagram of which one affects the lights that would be great).
    Not keen to empty my pockets with an Auto Electrician either...
    Suggestions?
    -DIDZ
    Camden, Sydney
    Its the headlight switch mate.
    Come past and try one for free if you like.
    Dec 2006
    A little late but thanks - that did the trick
    For an update: The red bitch cracked 500kms on a tank last week, unbelievable !!!
    -DIDZ
