It should be a CHE code. Virtually any gearbox out of a Mk3 Golf or Vento (except VR6) will work. I have one in my garage.
Anyone know the gearbox, tranny code thats in the Seat Ibiza Gti 95-97 running the 2E motor....thanks
is it possible to put a 95 gti gearbox into a 98 cupra?
Almost anything is possible but why you would want to put an 020 rod change gearbox into a car that has an O2A cable change gearbox is a little beyond me.
I thought the cupra like gears like stick in bucket whereas the gti 95' feels better.
Thanks guys for replaying..
---------- Post added 03-01-2012 at 12:01 AM ---------- Previous post was 02-01-2012 at 11:58 PM ----------
[/COLOR]Hi Bora Sport, thanks for replay. Mate my gear linkage keeps on breaking down any advise???
---------- Post added at 12:04 AM ---------- Previous post was at 12:01 AM ----------
So true, the gears in Cupra are not the best, used to own a 95 Seat Gti and you are right the gears feel much better.
Can you be more specific. What do you mean by breaking down? I know more about Cupras than the 8V GTi version however as far as I know the gear linkages should all be the same as a Mk 3 Golf and kits are easily available. Linkage kits are easy to find. Look in the Mk 3 Section I am sure that I remember reading threads about what to replace. I have replaced most of the linkages on our Vento and also when we had Mk 2 GTi's and it is not difficult.
Its all good now, took it to the mechanic and found a broken plastic bit somewhere under the stick box??? part replaced now its spot on![]()
Could you find out and advise us what the part number is of the bit that was replaced? Mine might need replacing as well.
