So have you ruled out all the spark side? Plug, coil, ect.
There are things called noids which you place between your injector and the wiring. These detect the pulse and flash so you can see if its getting a signal. Or pull the injector and take it to a shop for a spray test to see if its blocked or just not working. Find a good friend and swap injectors to see if it makes a differenc
