OK. Wait for the engine to be cold. Then check the water level, fill as required. See if car will start. Run for a little while then turn off and check for creamy goo under the oil cap and on the dipstick. If it is there, you blew the headgasket, if not, you were lucky. Those engines are strong and are usually ok if you turn it off when the buzzer sounds and did not add cold water to a hot engine. Fix the cooling system and It`ll probably be right.
PS please update your profile to show us your location.
