Results 1 to 6 of 6
Thread: Help
    Sep 2006
    Help
    OK, i had a bingle at the shops someone backed into me which broke my radiator mounts thus leakage. i didnt noticed and i drove to work, as i drove the engine begun to die and so i pulled over and saw hte dmg and i was WTF!, well in result my engine started smoking up of burnt oil from the rear of the engine and i was jumping up and down scrmeiang WTF!, i open the oil cap and there was smoke coming out of the engine>< oil burnt smoke aswell.
    so my real question is obviously over heated and cooked but did i blow a head gasket???
    aswell my oil light went on and BEEEPEED!!!! WTF!
    does that mean that the oil pump is not workin because i can hear the lifteres go at it really loud! ><
    someone please shred some light and tell me what has happen to the engine.
    aswell anyone have a seat cordoba 1.8 radiator/ front subframe??
    thanks
    tony!
    p.s MY GF GOT A GOLF MK5 GTI!!!!!
    Camden, Sydney
    OK. Wait for the engine to be cold. Then check the water level, fill as required. See if car will start. Run for a little while then turn off and check for creamy goo under the oil cap and on the dipstick. If it is there, you blew the headgasket, if not, you were lucky. Those engines are strong and are usually ok if you turn it off when the buzzer sounds and did not add cold water to a hot engine. Fix the cooling system and It`ll probably be right.
    PS please update your profile to show us your location.
    Mar 2006
    If it is the head gasket and you have comp insurance you might be able to make a claim for all the repairs.
    I've recently come across two examples of this scenario where someone has reversed into the car (both Vectra's). Both have had warped heads - one sounds just like yours except they ran it up a hill on a hot day (with a/c on)and the other similar when the tow bar blocked the water paths in the radiator. Strange because a front ender on a Vectra usually causes the second cooling fan to fail! Very expensive repairs for the insurance company!
    To convince the insurance company you may need to get a sympathetic professional engineer to argue your case!
    brackie Guest
    Talking But go for it!
    Quote Originally Posted by Tulyar
    You pay for this kind of thing happening so make sure you claim.
    Sep 2006
    Quote Originally Posted by brackie
    dude i only got 3rd party insurance! im not gonna get full comp for a 6.5k car!>< the insurance costs me 2k for full comp
    Camden, Sydney
    So have you established whether the engine is cactus or not?
