Results 1 to 4 of 4
Thread: Head Gasket Problem???
    Feb 2007
    Mount Evelyn
    G'day,
    Cordoba GLX 95
    I checked the oil today and when opening the oil cap, i spotted some of the dreaded oil/water mix on the cap.......car seems to go ok, so far.....could this be a head gasket problem??
    If it is does anyone know approx cost to get fixed.......
    Any answer would be much appreciated
    Aug 2007
    You say some, is it thick?? if you are having lots of stop starts and short journeys mate it you will get a bit of condensation and itll show on the cap slightly. Are you losing coolant? is your oil level increasing? your car is running good so sounds ok at this stage. Is you engine coolant hoses pressurising? if you are unsure have the system TK tested. TK test checks for combustion gases in your coolant system and the next stage is a cylinder leakage test. i think by the sound you are doing short trips and frequent stop starts???
    Jmac
    Alba European
    Adelaide hills, SA
    If you want to be 100% sure. It is also worthwhile to mention that Used Oil Analysis from the engine oil sample would give good assurance that your cooling system is healthy. It's cheaper than dismantle the engine to just take a look.
    Aug 2007
    True that transporter, you can have it analysed for around $70. Being signed up with Penrite has worked wonders in that department.
    Jmac
    Alba European
