Check the gear linkages that run from stick to gearbox.. The ones on my '98 Cordoba have worn and broke at the gearbox end resulting in a very similar feel to what you're describing. I found that the nylon bushes have perished causing a sloppier feel to changing and difficulty in changing into 1st & 2nd. Another thing to look at is pop your head under the dash and check the clutch/brake pedal mount.. mine broke and before it did also found it hard to select first... Btw welcome to forum and good luck
