Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Fan blower only working on setting two :(
    Dec 2008
    Sydney/Canberra
    You're in the right spot.
    Push on the copper contact switch and see if you can get all speeds working.
    If you pull the knob off, you can see all the inner workings.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Vic
    Quote Originally Posted by Umai Naa!! View Post
    I tested it all with the multimeter and it was fine. So I reached around the back of the dash and pushed on the plug going into the switch and its all good! So happy!
    Thanks for your help man!
    1999 MKII Seat Ibiza Cupra Sport
    2000 Audi TT Quattro
    2000 Audi B5 S4
    Jan 2006
    Lowood Qld
    I repl mine from my parts car as it was only working on hi
    too loud and blowing out foam dust...newby works on more settings 23&4 nice
    I thing if you pull it out you will find the contacts are worn and you maybe able to bend into place with nosepointpliers
    can also send you mine for cheap when I fix it..
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Jan 2006
    Lowood Qld
    undo the screw(s)
    pull it and rebend the terminals which are not touching where they shoul.
    Ihave a used one if u need
    many parts from my Cordy fit Ibi and Mk3 !!
    cheers
    B
