Results 1 to 10 of 14
Thread: Fan blower only working on setting two :(
    Vic
    Hi guys,
    All of a sudden my heater fan only works on setting two. Anyone have any idea on what the problem could be?
    1999 MKII Seat Ibiza Cupra Sport
    2000 Audi TT Quattro
    2000 Audi B5 S4
    Pacific Paradise QLD
    Quote Originally Posted by crazyazz View Post
    Hi guys,
    Broken switch
    Vic
    hard to fix?
    2000 Audi B5 S4
    Vic
    might check the resistor pack
    2000 Audi B5 S4
    Dec 2008
    Sydney/Canberra
    Fan speed resistor usually only lets it work on high.
    I'd be checking the switch contacts. They might neeed cleaning and adjusting.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Vic
    How do I get at them? Do I have to remove the whole unit?
    2000 Audi B5 S4
    Gosford Central Coast NSW
    no, under the glovebox, you should be able to remove the panel that holds the resistor pack from the base of the fan housing.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Vic
    I did see it was on the passenger side on the polo, the glove box on the Ibiza is under the steering wheel
    2000 Audi B5 S4
    Vic
    So its on the passenger side like the polo? Have to pull up all that foam like stuff and carpet under dash?
    2000 Audi B5 S4
    Vic
    Quote Originally Posted by Umai Naa!! View Post
    Think it is the switch now, I took the cover off and now it doesnt run at all.
    How do I check if its working? I cant figure out the crazy setup
    Also does it just pull out?
    Fan blower only working on setting two :(-sam_0514-large-jpg
    2000 Audi B5 S4
