just got it back in miracle time cost me $300 looks nice i refitted it in the car went to start it again nothingin going to burn it
william, I'm no expert in auto electrics let alone Seat auto electrics but I have on two occasions had similar probs to yours and in both instances it was leak back through diodes.
The last time was on my daughter's Commodore and at stationary, ignition off, it was leaking 4 amps.
I tested it myself with a multimeter (so it's not a difficult procedure) but I can't for the life of me remember how I did it. A google for it should come up with something - I'll have a look when I finish work.
In any event, the fix was to replace/recondition the alternator.
Apologies if that has been done or ruled out, I had a quick skim through the thread and didn't see it there.
which towing company are you using to get to the nats??????
I feel for you brother!!!!!!!!!!!!!
burn it!![]()
To test for drain from leaking diode you need to set your multimeter to amps. Remove the negative battery lead from the battery and connect your multimeter between the negative lead and the vehicle chassis. Multimeter reading should be zero.
It may not be your problem but it's a very easy test to do and it won't hurt to rule it out.
il try it but as i said i replaced the leads and grounds to the chassis il let you know how i go
i have power i go to crank the car you hear the solinoid work but it doesnt have enough power to crank but i reads 12.8 volts she just wont turn over its bizarre i put more petrol in it because there wasnt much in there next il check spark but there hasnt been a problem there i have a new coil new plugs and leads new alternator new fuel filter second hand sender so im lost
