Alternator is easy to test, voltmeter across the battery with the engine running. Should be looking at 13 plus volts easy.
Bootlight could be checked with the seat down or by dropping the back seat down.
Battery, is there any electrolyte in it? I replaced the battery on my Ibiza and when I took the old one off I noticed it was well low on fluid. That was pretty dead after Christmas and I had to bump it backwards off the drive.
Just charging it up doesn't prove that it's any good.
If you have volt meter you could check the current flow with the ignition off. Set the meter to amps and put it in line with the earth lead. Don't turn the ignition on cos most meters can only handle a small current. Maybe a few amps tops.
