Results 1 to 10 of 14
Thread: Do CV's "hum"?
    Do CV's "hum"?
    My wife's '95 Cordoba has for a few months been clicking when turning left at slow speed.
    I assume that is a cv (outboard?) but as of late it has developed a "hum" which is getting louder.
    Do cv's hum or is it more indicative of a wheel bearing (given that the cv is clicking)?
    Cheers...
    Jan 2006
    Lowood Qld
    wheelbearing but it may actually be from the rear wheels
    even though you suspect front...
    have some repl nos front or a whole shaft to fix all at the one go
    which side
    do u a deal, bernie
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Camden, Sydney
    click is probably cv. Hum is probably wheel bearing, sit in the back whilst someone else drives and see if you can hear which wheel.
    Rear kits are cheap and easy. Fronts you will need a press.
    Jan 2006
    Lowood Qld
    if it's the pass. side front bearing u won't need a press as i have a good stubaxle to trade with the bearing intact.
    also sell u the pas side shaft i got from loon 2/3 yrs ago 0 kms since then, nice c-v and rubbers...give u a hand over Easter if u need.
    Thanks for replies, guys.
    Thanks also karmen for offer of assistance. I appreciate it but I should be able to sort it out without imposing on you.
    I'll get it in the shed on the weekend and try to nail the problem down.
    Cheers...
    Well that was fun.
    Short answer is that both rear wheel bearings are shot.
    Passengers side sounds dry and is definitely the "hum".
    Drivers side has fair "push-pull" movement.
    What is of more immediate concern is the front passenger side strut top mount.
    I checked the fronts pass side first as I was convinced that was where the prob lie. I jacked the side of the car up, removed wheel and as I was fiddling around, discovered that the strut was flopping around at the top mount.
    Short story, I tried to tighten it, then removed the strut, removed coil spring, ascertained that everything was there (I think), put it back together and reinstalled it.
    The problem is that the upper rubber mount just sits freely in the strut tower.
    In the pic you can see the gap between the bottom of the cap and the top of the tower. Surely the strut should be a tight fit into the tower? The way it is, when the car is jacked up the strut drops by that amount between the cap and strut tower. The rubber mount itself looks fine, although it may well be compressed - I've got nothing to compare it with.
    Comments anyone?
    Also, does someone have the numbers of rear wheel bearings for '95 Cordoba?
    Cheers...
    Jan 2006
    Lowood Qld
    super cheap can tell u the nrs of the bearings
    and may have
    same with autobarn or repco
    or bearing place
    if i remember correctly the tower is loose if it is jacked up under the suspension
    double check the top nut any way and see what it is like when all wheels on ground.
    Camden, Sydney
    Rear Wheel bearings are the same as Golf 1, 2, 3 and all SEATs and more stuff beside.
    I carry them in stock and the strut tops if you cant find a local answer. None of the bits are very expensive.
    Cheers guys. The local bearing guy comes through work so I'll give him a call tomorrow.
    Is it correct that the upper strut rubber just "sits" in the tower?
    I guess if it works, it works, but I've never come across it before.
    Aug 2007
    I dont see anything wrong with that strut mate. It should sit like that.
    If you are doing the bearings yourself remember they are tapered and you need to adjust them properly, adjusting as you spin. You should be able to move the thrust washer behind the nut with a little bit of resistance.
    Jmac
    Alba European
