I'd do a bit of hunting on the net but I reckon you could get away with dropping 10-20% of the total weight. Any more and it'll be too weak I think.
EDIT
http://ecstuning.com/stage/edpd/page...ory=Drivetrain
I am planning on doing a job on the A3 soon, not sure the std clutch will hold up what I ahev planned for it.
ECS ship a flywheel that is 8lbs lighter than std!!!!!!!!!!!!!!!!
It would be harder to find someone to do a KR one Static as they are a back to front clutch and would need a special jig.
They are also not as heavy as a VR6 or Cupra one.
Its the same flywheel as a T4 4cyl and a G60, I took 6kg's of the Caddy flywheel and it still idles smooth and revs so much better. Just remember to get it balanced after machining.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
The Cupra flywheels I mean not the KR ones.
i wouldnt mind doing this but theres no way im touching it how much you reckon a mechanic would charge for the whole thing? should i get a new clutch whilst im at it? Its for a 1995 ibiza GTI BTW
ok thanks answered my question there.i sent you an email about parts to btw flywheel question was in there so just ignore that part.Thanks again.
