Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: Cupra mini build thread - Blanco Gringo!
    Jun 2012
    Hackett, ACT
    Needs moar awd and boost.
    Hai Mick...
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by DognamedElvis View Post
    Hai Mick...
    Haha, Pete you so funny! How was Marulan? Thanks also for the top hose.
    Aug 2006
    Melbourne VIC
    What do you mean by tuning it? Did you get the ecu chipped?
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by Water Boy View Post
    Garlock EPROM is on order but for now it has had;
    - New pod filter
    - New oil/filter
    - Remove/clean/refit Idle Stabilising Valve (was filthy) with upper cylinder cleaner
    - Clean vacuum runner in the manifold with upper cylinder cleaner
    - Replace perished vacuum lines
    - Clean throttle body
    - Adjust accelerator cable tension
    - Remove/clean/refit distributor cap
    So when the EPROM comes we will also replace the lambda probe.
    Looking for more low end power (did a TLGP with Liam's GTI on the weekend and it was almost neck and neck!! I expected it to be a bit faster)
    Jul 2005
    Newcastle, NSW
    Subtle lows and decent shocks about to appear!
    Vic
    I haven't heard of this Garlock ECU remap before, where can I find info on it? What gains are found on a totally stock ABF? Or is it a waste of time with out exhaust / intake cam etc
    1999 MKII Seat Ibiza Cupra Sport
    2000 Audi TT Quattro
    2000 Audi B5 S4
    Aug 2006
    Melbourne VIC
    Keen on info about that suspension Mik?
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by crazyazz View Post
    This is like a secret chip. Hardly anyone speaking English have tested them but search google and do some translating and it will reveal some info. In short I'm buying it on spec, no idea if its going to do much but am considering a dyno beforehand and after to get some real numbers and more tuning data.
    Our car has stock exhaust but allegedly dual KR exhaust cams, and I've put an adjustable cam gear on for advance.
    Jul 2005
    Newcastle, NSW
    H&R from Germany. Comes in comfort 30mm drop or Sport 50mm drop. Budget around $700 shipped.
    Jul 2005
    Newcastle, NSW
    Not bad for a half cocked tune effort on a little 2.0 NA engine.
