Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Cold start up issue
    Apr 2014
    Ridgehaven South Australia
    Cold start up issue
    Okay I am not sure if I am being paranoid...... when I start the car up after it has being sitting overnight it turns over but when you give it some pedal it just cuts out.... You do that 2 or three times and then starts up fine and you have no problems for the rest of the day. Talked to the previous owner and he seems to think its normal. I changed the spark plugs this morning and hasn't made much of a difference. I done plenty of research on the countless forums and I haven't got a definite answer.
    Thanks
    Ryan
    Jun 2009
    Sunshine Coast, Queensland
    You should check your fuel pressure ---- may have a leaky fuel pressure regulator
    Locate the fuel pump relay and work out how to jump it. So the pump runs constantly. Then try starting, see how it goes. I wonder if the pressure is dropping overnight and the pump isn't priming enough for a start.
    Apr 2014
    Okay thanks for the quick reply..... After a bit of research testing fuel pressure reg is something I should be able to do. Do you think I should be checking leads and dist cap as well.
    Sent from my SM-G900I using Tapatalk
    is the pump priming as soon as you get lights on the dash (on position?). Its quite loud
    'I spent a lot of money on booze, birds and fast cars. The rest I just squandered' - George Best
    Apr 2014
    Yeah pretty sure its priming on start up.... Just doesn't get that second kick that keeps it idling. Went to repco today to buy a fuel injection pressure tester but $500 just isnt worth it. Im thinking of just buying the fuel pressure regulator and taking the chance that it will fix it.
    Apr 2014
    Whats that a tester or the fpr
    Apr 2014
    Sorry dum question gotta be the tester
    Fuel system in general. depends where you plumb it in.
