Results 1 to 5 of 5
Thread: Broken Door Lock - 96 Ibiza GTi
    Apr 2008
    Geelong, Vic
    Something gave the other day when I unlocked the driver's side door - the key now turns through 180 deg. each way with very little resistance, and won't unlock the car... The aftermarket remote quit a while ago too, so I'm down to locking and unlocking from the passenger side.
    Any likely causes?
    How do I get the door panel off?
    Thanks!
    Rick
    1996 SEAT Ibiza GTi
    1970 Porsche 914
    1956 VW Beetle
    Camden, Sydney
    The lock eccentric has broken mate.
    I can sell you a new one for $20.
    You dont need to take off the doortrim, simply undoo the allen bolt in the end of the door that holds the handle in. Tap the handle briskly forward and pull it out of the door.
    You can swop the left and right handles to give you drivers side control as a temp fix.
    Apr 2008
    Geelong, Vic
    Perfect, I'll give you a call in the next couple of days.
    Thanks!
    Rick
    1996 SEAT Ibiza GTi
    1970 Porsche 914
    1956 VW Beetle
    croydon nth, vic
    i used golf mk 3 lock repair kits outta vw not too expensive same deal did not have to take off door trim... unless you drop the broken bit inside door, good luck
    Camden, Sydney
    Quote Originally Posted by cgti73 View Post
    Mk3 rods are longer and you might have to machine a bit off.
