Results 1 to 10 of 20
Thread: BACK FROM THE DEAD.... again
    Maitland, NSW
    Talking BACK FROM THE DEAD.... again
    Hi all,
    thought i best get back into it now i've got some spare time and all.. (made redundant as of today)
    my toledo is still rockin along nicely.
    except for a coupla tiny fings.
    1.a very intermittent fault with starting the engine.. only fires 3 cylinders..but after 30seconds its all good.
    2.the handbrake isnt working again(newy crew? i think i need new cables?)
    3.i think i have a leak in the coolant. every few months the light flashes until i top it up.. altho i drove it to sydney and back and around newy for a month with it flashing and it never went past halfway on the temp guage..
    hows everyone else doin? whens the next cruise!
    ps: is the handbrake tested for a pink slip? rego is due on 1st march :/
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
    May 2006
    Maryborough Vic
    Post
    hate to worry you but !!
    not running on all cylinders on start up and a coolant loss
    is a sign of a blown head gasket
    when the car is up to temp and parked for night
    coolant can leak into a cylinder
    then when you start it in morning it will run rough until it clears the coolant
    i'd get it checked out
    sorry
    Camden, Sydney
    Or it could be a dodgy ht lead and a crack in the water outlet housing.
    my Polo has the same problem with the coolant, after a couple of months the light will flash at me telling me to top it up.
    also if i leave my car for a couple of weeks itll run on 3 cylinders and then fire back onto 4 after a few seconds.
    Nov 2007
    Hate to say.. but the handbrake is a roadworthy item, unless of course you get someone who isnt that thorough in doing a pink slip inspection.
    Maitland, NSW
    thanks for the info guys.
    im only going off what people have said in looking at it.. ayden loosened both the cables at the back of the wheels then pulled then down and tightened which seemed to have resolved the problem.. but its now happeneing again.. would that mean i need new cables cause they are seizing??
    or would it be worht just taking it to somewhere that does both handbrakes and pinkslips?
