Welcome Kris, hope your time with the cupra is long & fun filled!
I to had a look at the different airbox mods on the various forums & came to the conclusion that apart from sounding great they did little in the way of improving performance. I decided to be conservative, I replaced the filter with a K & N panel & drilled out the front trumpet behind the headlight to a larger diameter & fitted a larger pipe between the box & the coldair fitting behind the headlight. I considered running a second pipe down into the bottom of the front airdam but decided against it, to much mucking around for little gain.
I to like the better/deeper sound & I consider that the engine does feel stronger & doesn't run out of breath in the topend as early as it used to, this is just a seat of the pants type of feel & nothing scientific!
anyway, enjoy.
cheers
Phil
