Did you spray down the throat of the carby or the outside?
If it was down the throat then it sounds like your choke isn't working. The choke adds more fuel while the car is warming up and then turns off when it's warm so you don't use heaps of fuel.
If you sprayed outside the carby then you've got an air leak where you sprayed.
