Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 95 Ibiza just purchased
    I purchased a 1995 Seat Ibiza 1.4l on Saturday as a little commuter to drive to and from work.
    It needs a little bit of work and some parts, and was surprised to find such little information about them on the internet.
    Firstly, where would one be able to get spare parts for these in Melbourne (or posted from elsewhere)?
    And, where would I get a repair manual for these (or would anyone know torque settings etc)?
    Just thought I'd also do a little repair thread. Here she is before I started tidying her up.
    There's a few dings and scrapes here and there, plus a leak in the exhaust, but it runs really nicely, and drives well.
    Any helpful hints and words of wisdom will be greatly appreciated!
    Attached Thumbnails Attached Thumbnails 95 Ibiza just purchased-img_3035-jpg   95 Ibiza just purchased-img_3034-jpg
    Aug 2006
    Melbourne VIC
    Hi mate cool to see another Ibiza geek.
    Do you still have your Bora?
    Any VW specialist will be able to get Seat parts. Remember they are a mix of Mk2/3 Golf.
    Lots of self serve wreckers will have an Ibiza or two.
    I think tonijov is out your way and a Seat expert!
    Thanks! Still got the bora. Just bought this to commute to my new job.
    Im just keen to work on something a little bit different!
    Jan 2006
    Lowood Qld
    Parting a 95 Cordoba here with lots of gear left on it. low kms on all
    am in Qld but ego-online shipping is cheap will post anything'
    send me a list what u need/want on messages send your email and will mail pics of parts
    very low maintenance cars and easy to maintain had 4 in the Family...strong and mostly vw German mechanical parts (Mk3)
    K
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Thanks!
    Slow process, but I will shout out if I need anything!
    So, bit of a gap in posting, but I have been doing a little bit of work, and I'm hoping to get the little beast on the road when I get back from a trip to NZ.
    So far I have straightened the front end (including some home panel beating), re-painted the lower bumper, plus some other small parts in the bay, repaired the back seat mechanism and done some maintenance to the engine.
    It's had a service with fresh oil and filter, ignition leads, plugs, coil pack, distributor cap, distributor coil, fuel filter (should've seen the fuel that came out of it!), new battery and a repair to the exhaust manifold/a few exhaust gaskets.
    It is however running pretty rough, sitting at 750 RPM and has a bit of a wobble going on.
    Does anyone have any ideas on what I would be missing? Perhaps the carb needs a tune?
    Start by looking for any vacuum leaks when running. Spray some carb cleaner around the carby and see if the revs change.
    You could also increase the revs when idling to about 900 and see if it's any better.
    Paul
    Thanks!
    Will have another look at it when I get a chance.
    I did do a few vacuum hoses not that long ago, but not all.
    Will post back with some more progress soon.
    Update: tightened the low limit screw on the carby, bringing the revs up a little (probably only a quarter turn, but still only ~800rpm idle), and gave the carby a quick squirt with carby cleaner. The revs picked up a fair bit, so I'm guessing (with my very limited knowledge of carburetors) that it's lacking in fuel/running lean. Any idea how to adjust air/fuel ratio?
    Jan 2017
    hobart
    Or it has an air leak from a gasket or a vacuum hose.
    I h=am wrecking a Toledo if you need some parts, not sure how compatible some parts are.
