Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Wiper blades
    Jul 2012
    Lota, Queensland
    Had my UG R for a while now an no probs with the wipers. I normally apply some Rainex to avoid having the wipers on at all but so far it's not been required even during the last few wet months here in Brisbane.
    Mar 2009
    Melb
    It could be down to dealer prep. Some of us may have had some crap off the windshield causing the blades to judder.
    Tig 162 R-Line; Audi TT
    Jan 2010
    UK Cheshire
    As far as I know, the windscreen wiper problem has never been formally resolved. There is a TPI, 2013403/9 dated Dec 2009 but this does not address the Scirocco owner's experiences.
    There appear to be 4 versions of the infamous smear.
    1. Waxes and polishes, particularly nano type. The TPI refers to this problem only.
    (Fix: Clean windscreen with Window Cleaner - part no. G 052 184 A2).
    2. Deformed windscreen areas leading to shallow depressions which the wiper skips over.
    (Fix: New windscreen)
    3. Minute droplets of windscreen adhesive on the windscreen surface left during production assembly which gradually spread to ultra thin patches about 25cm - 40cm across.
    (Fix: Remove adhesive patch ( polyurethane based)).
    4. The Scirocco's plastic wiper carrier of the blade assembly which holds the wiper rubber itself collapses in the central portion under the downward force of the wiper arm, slightly squoshing the wiper rubber. This can be checked by bringing the arms upto the vertical service position and check the plastic carrier runs parallel to the windscreen at about a 6mm constant height above the windscreen surface. Measurement is not critical, constant height is.
    (Fix: Fit Mk6 Jetta wipers part no. 5K2 955 426 (Driver side)/5K2 955 425 (Passenger side) which can be done as warranty items, VW (UK) used this after discussions with VW Germany. Or pay for your own, aka Bosch equivalents.)
    I had 3 & 4 problems above. Had the Jetta wipers option on for 2.5 years now and not looked back.
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
    Jul 2012
    Sydney, Australia
    Thanks, RW1. I must say that I had applied a Nanolex glass sealant before first using the wipers but the Bosch's replacements works fine. I reapplied the sealant a couple of days ago and shall see if there is any problems the next time it rains.
    Quote Originally Posted by Car Nut View Post
    Please let me know how it went.
    i had the same problem, got paint protection at Reflect effect, he must applied sealant on the glass, wiper blades squeaking and shuddering when i turned it on last week. havent use the wipers before that, so not sure its the sealant or the wiper, but definately annoying.
