Results 11 to 20 of 22
Thread: What standard tyre did you get with new car?
    RE050A's from Bryan byrt.. nothing wrong with them, a friend with a 135 went from these to super sports and says they are in another class of grip.
    tire rack shipped for 1350.
    Dec 2012
    Quote Originally Posted by vwryogi View Post
    For the 19" potenza owners...what tyre pressure are you pumping em at? I went cold to the servo and went to pump mine at 36psi aspect the side panel...and saw on the meter that it read 40psi all round...
    Any ideas?
    Jan 2009
    Quote Originally Posted by bigbadrat View Post
    Any ideas?
    What does the sticker on the fuel flap say?
    IIRC, it's 38 psi (cold) front and rear (normal load), but you can leave them at 40 psi if you wish.
    Any ideas?
    advice from a garage was to go to 40psi cold.. specially on our low profiles.
    Dec 2012
    Thanks for the replies!
    Feel a little bit better now knowing its ok at around the 38-40psi mark. Was starting to get worried as scirocco central guys posted around the 33psi mark in older posts for their 19s.
    Cheers and ride on!!!!
    Jan 2009
    33 psi (2.3 bar) is for 18" tyres on the Scirocco R.
    38 psi (2.6 bar) is for 19" tyres on the Scirocco R.
    Non-R versions have different tyre pressures again.
    Dec 2012
    Sutherland Shire, Sydney
    At the VW driver education day both the instructors (racing drivers) and the VW tech support team were saying ~38 psi for 18" and 19"
    This gives good turn in feel and can increase tyre life/mileage
    Jan 2009
    I was quoting the factory specs.
    But there's no reason why one can't adjust the pressures to suit one's needs (full load, track days, different ride or handling response/feel, etc).
    However, on public roads, it's never advisable to go below the factory specs. Or above the tyre's maximum inflation pressure (as stated on the sidewall).
    Dec 2012
    Yes mate, understood, I was not having a go at your post
    It's a good point about increasing tyre pressure for full load
    I doubt many people do this but it's clearly detailed on my car (wagon)
    Jan 2009
    No worries, just wanted to clarify/emphasise the source of the figures to avoid any potential/further confusion.
