Like all cars, the Mustang has had a couple of teething problems for the Aus market given its the 1st RHD Mustang ever built in the factory.
The early cars 2015 up to mid 2016 has the Sync 2 radio system which is clunky to use and slow. From mid 2016 onwards Sync 3 came out (still current today) and is actually pretty good.
The biggest issue is that due to the RHD build the headers are different to the LHD cars, which means you cannot simply buy headers (and there is 30kw to be found in good headers) from the USA. What this also means is that the oil cooler (oil/water cooler) sits close to the RH header and in the early models 2015 to mid 2016, this lead to failures of the welds leading to burst coolers, leading shortly thereafter to total engine failure. From late 2016 onwards upgraded oil coolers were fitted by the factory and is available a free refit to older cars (like a recall but quietly
). Aftermarket oil cooler solutions are available that totally removes this as an issue and I plan to fit 1 soon even though I have a Feb 2017 build (on my son's birthday actually) car.
So if you are shopping early cars, ask if the cooler has been replaced (or even the engine, which is done under warranty no questions asked), otherwise look at cars built from about Oct 2016 onwards.
It looks like the Mustangs are holding their value much better than the Golf R secondhand. For cars that cost the same new (more or less) the difference 2nd hand looks like at least $10,000 on average.
