Page 9 of 21 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 206
Thread: Tigger73's Scirocco R
  1. #81
    Quote Originally Posted by iampivot View Post
    Is that a screw sitting in your tyre?
    I'll check but I think it was just a piece of gravel/rock.
    Oct 2009
    Canberra
    Ran the car on the dyno today - 222kwaw...
    Got the same power out of my R but with the torque hitting around 433nm. No HPFP or IC although the IC is getting installed next Thursday.
    Is it an IS38 turbo in the Rock?
    Current:
    2023 Mk2 Tiguan R - Lapiz Blue
    2015 Mk7 Golf R Wolfsburg - Limestone Grey: Stage 2
    Gone but not forgotten: 2008 Polo GTI Shadow Blue
  3. #83
    Quote Originally Posted by Servo View Post
    Scirocco has the same engine as Mk6 R with the K04 turbo.
    Jul 2011
    AU
    Installed a Ramair CAI.
    Put my RamAir intake on this week. Man it is loud! My wife isn't a fan (but I don't particularly care) haha.
    Did you have to modify (trim) the aluminium heat shield plate to fit around the headlight and radiator pipe?
  5. #85
    Quote Originally Posted by Tobes_WIR35 View Post
    Yes it is loud and my wife is not a fan either (she feels a bit self-conscious when driving and thinks everyone is looking at her).
    No modification necessary. I had some clearance concerns with the fan, however when the 2 parts of the cover bolted up it pulled the bottom section away.
    Jul 2011
    AU
    Wierd... maybe they sent the wrong plate. I had to cut out a 50mm radius U shaped piece out of the plate for one of the vertical piped and also had to cut a square piece off to clear the back of the headlight... worked fine though I just cut it, filed it and sprayed it black.
  7. #87
    Jul 2011
    AU
    Do you know whether it's possibly to tighten the diverter valve spring so it doesn't discharge at such low boost levels? I'd prefer to hear a bit of flutter rather than the long pssshhhtt noise...
  8. #88
    I'd already installed a Forge DV so haven't run it with the stock DV.
    OK after further consideration I've decided to go back to stage 1. Boss at work had made some comments and wife wasn't happy with the noise. I'm not really concerned eitehr way but I understand the boss' point of view (it's a company paid for vehicle).
    Anyway my loss is your gain. Exhaust and intake have been removed and are for sale:
    Ramair Intake (Audi/VW 2.0 TFSI K03/04) - $180
    Scirocco R 3" stainless turbo-back valved exhaust + wifi switch kit - $2950
    Went past the grain silos at Coonalpyn today and took a compulsory photo...
