Put on some C.Quartz paint protection... used it as an excuse to take some shots of the car with beading:
Mesmerising....
I did this one a little while back when I changed plates I removed the front number plate monstrosity.
The screws the dealer used the screw into the plate holder actually also went through the front bumper so I just reused the same holes. Otherwise I probably would have lifted up the plate a bit.
Used some carpentery stick on screw covers painted to body colour to cover the holes left from the plate bracket. One of the other local Scirocco guys had a sheet of them sprayed. If I'm really keen I'll get the holes filled and sprayed but these work pretty well in the meantime.
