Results 1 to 10 of 18
Thread: Standard Suspension measurements
    I picked up my Eibach Pro-Kit springs today from Eibach at Warriewood and they measured the wheel arch gap so that we can compare it later after I have had the springs fitted.
    We found it to be a little strange as the numbers below will indicate...
    Measured from the underside of the Guard to the centre of the wheel.
    Drivers side Front - 370mm
    Passengers side Front - 379mm
    Drivers side Rear - 375mm
    Passengers side Rear - 370mm
    I was not in the car at the time and fuel was at 50%. Even if the car was empty the 40 kg (55 lires) would not make that much of a difference.
    So guys and girl (s).. get your tape measures out and lets have a comparison of standard cars... Bain can provide us with lowered figures
    Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
    Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
    Jun 2009
    The battery is pretty heavy and there are a lot of other bits and pieces that aren't in the middle.
    That is why when you get adjustable coilies that it's not always the best idea to have them even all around.
    Quote Originally Posted by team_v View Post
    That doesn't make any sense... the passengers side front sits higher... WITH everything in the car...the battery is not in any way heavy enough to have any effect...
    Actually that is one of the benefits of adjustable Coil Overs... you can adjust them to level the car out.. specifically when the driver is in it...
    Jan 2012
    Quote Originally Posted by Andych View Post
    What about if one doesn't have a tape measure?
    MY12 Scirocco R - slightly not stock :rolleyes:
    Umm have your detailer measure them tomorrow..
    Jun 2009
    Jeez, go off much?
    I was adding information that is directly relevent to your post.
    The batter is pretty heavy compared to a lot of other components, then you have a lot of other items such as rear muffler etc.
    It probably also accounts for a full fuel tank and levelling/wearing over time.
    The car isn't meant to be dead level so if you level it out with coils you will be putting extra pressure on components which will make them wear out faster.
    Jeez, go off much?
    Really.... lets see how relevant.
    As I said before...the battery is already in the car..and on the passengers front.. it doesn't get heavier with age..that is the side which is high... relevant.. Um no...
    The rear muffler... is central and equally weighted per side... relevant... Um no...
    The fuel tank is central... and it was half full.. even if empty it is only a difference of 40 kg... and equally distributed side to side... relevant... Um.. no
    So you are saying that VW and all manufacturers make their vehicles to be warped so that they don't wear out as fast as they would if they were level???
    Unless you have specific Scirocco standard suspension measurements...it isn't relevant to this thread...
    Jun 2009
    I am more than happy for you to pull apart the entire car to work out what components weigh more and sit in off-centre locations.
    The jack sits on one side of the car, the windscreen washer bottle also, as well as the coolant bottle.
    Every little bit adds up, hell there is probably more intercooler piping on one side than the other as well as well as a single reverse light connector.
    The stock muffler does actually have an extra pipe on the right hand side which would add a bit more weight and has the kink which puts further weight on the left hand side. See here: http://www.millteksport.com/images/custom/983.jpg
    Also the fuel tank does actually have more storage on the drivers side when full.
    My point was that VW and a lot of other manufacturers don't have cars that sit dead level on each corner from the factory so if you level it out you will be putting more stress on the suspension components than the factory had designed them for.
    Obviously you have a chip on your shoulder still about the soundaktor.
    You obviously have no idea what you are talking about... it is a really simple concept... I have not touched the car... the battery and all those other items you mention are all there already... AS STOCK STANDARD... the car sits with the PASSENGER side FRONT higher than the drivers side front... and the DRIVERS side REAR sits lower than the passengers side... the weight of those items is irrelevant....just as your posts...
    I never suggested my car should be dead level... you brought that up... and the reality is that most cars are designed to ride level with a Standard driver weight.. therefore they should be slightly higher on the drivers side when stationary... without the driver.. but I doubt you will understand such a simple premise....
    Right... like I could care less.. as I said before... you have nothing relevant to add to this thread.
    MMM I was thinking the fat b$%tard sitting in the drivers seat has, over time, permanently deformed the springs which in turn has put the others out of whack ROFLMAO
    Mine is probably gunna have the same problem ha ha ha I think it is time to lighten up a bit.
    Scirocco R with DSG in Viper Green
    Window tint, paint and fabric protection, GPS tracker
