DNA Tuning is what you are looking for if you want the ability to DIY install/remove the tune at your leisure with the included hand controller.
Does anyone know where I can get the stage 1 software for my stock scirocco R so i can flash it in to the ecu myself?? Many thanks
Yes will give them a try and let you guys know how I go
Hi Guys, Below is my Dyno Graph of a stage 1 Bluefin map.
No engine, intake or exhaust mods.
98 Ron Fuel.
DSG 4th Gear dyno run.
On the day of the Dyno run the Temperature was 35 Deg C in Brisbane.
I've done the stage 2+ with VW Racingline(OEM+) and it is excellent.Having been an APR dealer for 16 years and now swapped to OEM+ I can really say the new tune is much better on front drive cars. See Canberra VW Centre in Belconnen. Only prob is you can't load it yourself but it's the end result that counts,is it not?
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
