Results 1 to 10 of 13
Thread: spacer question
    Jan 2015
    spacer question
    Hey Guys,
    If i'm running stock wheels with H&R lowering kit on the roc what is a good size bolt on spacer to go to sit nicely on a daily ride?
    I tried searching the forums and couldn't find the answers to what i needed
    Thanks
    D
    Personal opinion on what fits nicely and what doesnt. Throw a tape measure on the wheel and see how much you would like it to come out. 5mm = 5mm spacer.
    Keep in mind they are illegal in OZ. Make sure you get a decent quality one with correct specs and botls
    If you want to stay legal then get a new set of wheels with the correct offset.
    Jan 2015
    legal or not - i actually like the stock wheels with a lowering kit i just want to fill the guards a bit more.
    Quote Originally Posted by Dee View Post
    Yeah I wasn't saying anything about not liking the stock wheels. You just need to get a wheel (OEM or not) with a different offset
    If you want to fill out the guards you need to go to some thing like 18 or 19x8 ET35.
    Canberra
    I ran a 12.5mm on the stock wheels without any problems with the H&R kit, and I've seen 15mm on the same. 15mm is probably as far as you'd want to go before you get undue attention.
    Running now 12.5mm spacer on 19x8.5 ET45 (so that's equivalent of nearly ET33).
    Mar 2015
    Cecil Hills, NSW
    Quote Originally Posted by DVSTwig View Post
    Hey DVSTwig, did you use your stock bolts?
    2012 VW Scirocco R 2.0L TSI - Candy White
    With a spacer anything more than say 5mm you really should use new extended bolts...
    Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
    Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
    Canberra
    Agreed, I used extended bolts. I even purchased another four VW plastic caps so that I you didn't see them. 1 of the 4 stock caps is to fit the lock nut, and wont fit the extended nuts.
    EDIT:
    This is the set I'm using
    spacer question-183113_x800-jpg
    Jul 2010
    Sydney NSW
    I reckon you can come out 15-20mm to sit flush. Not sure if you want to actually go that far with a spacer tho
