Very easy to install mate. Open the boot and use a flat piece of plastic to unclip the small carpet squares on each side of the boot.
Unscrew the white plastic butterfly bolts inside the hole where you removed the square panel and gently pull the light out remembering to unclip the electricals which all go into a plug at the back of the light just after you pull it out a little way.
