Page 45 of 58 FirstFirst ... 35434445464755 ... LastLast
Results 441 to 450 of 576
Thread: Scirocco r mods
  1. #441
    Aug 2008
    Quote Originally Posted by BLAKROC View Post
    Looks awesome mate!
    Last i read on vwgolf.net you were on to the water meth and KO4 hybrid?!? How's the power figures on that??
    Thanks mate for the reminder I better I update my build.
    For the moment I have not adjusted my tune, advanced the timing or increased boost to work with the water meth. I don't want to be dependent on it so I have installed it with a On/off switch. Logs taken so far have proven what its primary function is being to cool the intake charge. On a hot day with outside temps in the 30's and ambient temp in the 40's the car maintained power at the dyno of 245 to 252 kw which were power figures take on the dyno when temps were in the low 20's. Timing was nut pulled in higher RPM's due to heat soak with the meth and results were within 0.6 of timing set. Without water meth it pulled back up to 6 degrees. So it works.
    As a general rule (or really just to have some fun) I turn it on when teamps hit 30 and I can instantly feel the engine response. Liken it to a cool day when you take it for a run or like my previous cars which ran on aviation fuel.
    It is definitely a worthwhile upgrade and worth mucking around with.
  2. #442
    Sep 2008
    WA
    Nice power figures and yeah sounds like a worthwhile upgrade for sure.. I've still got some hardware and stages to progress through before I think about it..
    What DP are you running if you don't mind me asking? I've been looking at SPM pretty closely, maybe Eurojet or Milltek
    Stage II Scirocco R
    Previous: Stage I Polo GTI
  3. #443
    Aug 2008
    Scirocco r mods
    My DP is a customized item to fit the hybrid turbo. I personally had both brands you mentioned and happy with both. I like the eurojet for the v band connections and is well fabricated.
  4. #444
    Apr 2012
    Maidstone, VIC
    :O Looks bloody awesome Rev. Want! Just curious, but can I ask how much the bonnet was... ? Just a ball-park figure will do haha.
  5. #445
    Aug 2008
    Quote Originally Posted by kazmeyers View Post
    Don't ask
  6. #446
    Apr 2012
    Maidstone, VIC
    Ahh, at least I tried.
  7. #447
    Jan 2013
    Upper North Shore, Sydney
    Did some basic suspension upgrades today, had my mechanic taken some pictures for me
    H&R springs
    HPA mount
    Thickest H&R sway bars 28mm/24mm soft setting
    WALK
  8. #448
    Jan 2013
    What I did last weekend at home Just can't stop playing with it...
  9. #449
    Jan 2012
    Epping, NSW
    nice suspension mod pics!
    What is the NVH like with the engine mount and Whiteline anti lift kit?
  10. #450
    Jan 2013
    Just drove it for about 30km just now, I have a DSG, so the first feeling is there are more vibrations and noise when it is idle on D, and at low rev, but as soon as the turbo kicks in, it is much better. So I have to leave at N when stop in front of traffic light so not sure where it comes from (with my very limited mechanical knowledge ), I suspect the mount hasn't been settled.
    The NVH probably won't change much for WAIK.
    I just love the cornering grip it added along with sway bars, and can feel that the body roll is definitely reduced. Hmm, the other thing probably is a little more harsh on Normal mode. But not an issue for daily ride. Love it
    I was trying to search around to see what other forum's comments after done similar/same upgrade.
    Quote Originally Posted by tonymy01 View Post
