Page 1 of 37 12311 ... LastLast
Results 1 to 10 of 576
Thread: Scirocco r mods
    Jan 2012
    Scirocco r mods
    Hi anyone planning to do aftermarket modifications? If so what are your potential mods?
    After getting a rear sway bar, I'm planning to get coil overs/springs, does anyone know if it will affect the Adaptive chassis control?
    Oct 2010
    Melbourne, VIC
    I think KW make the only coilovers that are compatible with ACC. It will be disabled with other brands AFAIK
    http://www.evlmotorsports.com.au/kw-...amper-control/
    Resident grumpy old fart
    Jan 2012
    Melbourne - South East
    After the 3k service I'll be lowering, new rims and possibly an aftermarket tune. Part from that I'll be getting some grey tint heh.
    Those coil overs look nice so will check into the pricing of those.
    Scirocco R - Candy White, Sat Nav,tinted windows, H&R Springs, 19x9 ETA BETA Tettsut X Black rims.
    Audi S3 Sedan - Riviera Blue Exclusive paint, PP2, H&R Super Sport springs
    Well... there is the other thread that has info on Reversing Camera and an expression of interest for Carbon Fibre mirror caps... plus another one about APR... perhaps they should all be rolled into one thread.
    ---------- Post added at 08:37 AM ---------- Previous post was at 08:34 AM ----------
    Quote Originally Posted by Bain View Post
    The coil overs are the ONLY way to get the sort of stance that 10d has on his black one.. but damn they are expensive for the ACC compatible ones. I will pass....
    Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
    Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
    I'm getting a VWR air intake, votex CUP spoiler (fiberglass, already ordered) and paint the rims.... and a tune by maybe Veizu? to follow.
    Jan 2012
    Quote Originally Posted by Andych View Post
    hmm K-mac make custom springs. If the coilovers are super expensive, I think ill go with some Eibach springs first off and do the changeover myself.
    Did anyone read the Scirocco Wheels COTY write up? Sum it up... great car... suspension on the standard 19 inch wheel way to harsh.
    Jan 2012
    Depends what you're after. I prefer harder suspension to the boaT like suspension most people are used to.
    Quote Originally Posted by pologti18t View Post
    Also read the roads they used.. Personally when I tested the Roc it was on pretty ordinary roads.. certainly not super smooth freeways / motorways (do they exist in NSW) and the suspension was set to normal. I didn't change the setting but found the ride to be firm but perfectly acceptable for a 3 door Sport Coupe.
    There was / is a similar argument that is ongoing with the Golf R about 19's vs 18's and ride etc...
    Personally.... I would have ordered it with 19's anyway...
    ST2 paddle extensions work just as they do with Mk6 R or GTI. There was an extended Group Buy on them but not sure if it is still going.
    No idea about Maniacs.... got a link?
    Hear you go..
    http://www.ecstuning.com/Flyer-Maniacs/ES1892535/
