Joe
traction is better for sure, you wont regret it.
You shouldnt have any dramas with the OZ Racing wheels.. they are right up there with BBS etc so quality and info is extremely good.
To be honest.. Forged wheels are probably not worth the extra you pay unless you are super serious about weight savings etc.. The cost difference is massive.
Personally.. I would stick to tyre sizes you can get here.. I would buy them from Tirerack though... at least that way if your ever have a major tyre failure you are not waiting a week or more to get a replacement.. and you are more likely to damage a rim on 255x30 than on 255x35.
They really dont affect your speedo much and they help to fill the guards better.... plus the ride is a little bit better...
No real need to go with different sizes front to rear... in fact you are better not to as it means you can balance tyre wear across all 4 tyres...and then the rims are all the same size as well...
I guess it all depends on the look you want... mine are probably 1/2 an inch too wide on the rear.. but the look is fabulous with the deep lips on the rear.
Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
Joe
Thanks John, really looking forward to the upgrade!
Thanks Andy, OK I decide to do same size all around. I was actually getting Tirerack to send me the tyres too, and AMG Australia for the rims, I can take my time to apply sealant to the rims and have them fitted and balanced afterwards to keep my life easy.
Yeah I agree the forged wheels are really for rigidity which I don't think I would need unless being a frequent track racer. Probably not even needed if just doing drag racing. Save money for another set of 18" for track if I ever go.
Thanks Bec, you were up early! The Brembo only makes 4 piston for the Scirocco R, not big enough sitting behind 19 inch wheels imo, so will try to get a 6 piston one and deciding the size of rotors by then, likely 350/355 whichever is available with the Brembo Type 3 rotors.
Does anyone have a dash cam? I'm paranoid about someone doing a hit and run while I'm parked?
Stock VW Scirocco R Rising Blue
A bit of shameless self-promotion here - my APR Cat-back is for sale in the parts forum in case anyone is interested...Im running stock again until I work out what combination is going to give me a decent note without being too 'extreme'.
