this is not really a mod question but has anyone here used launch control on their rocco R?
I'm not expecting anything spectacular since it's FWD but a few rpms off the line would certainly be beneficial.
is the procedure:
touch ESP button briefly to turn off TRC
then hold down ESP button for 5 sec or so to turn off ESP
select the DSG S mode
left foot on brake
right foot push throttle to the floor
revs should rise at this point to whatever the LC set point is (i'm guessing fairly low on the FWD roccos, maybe 3,000rpm?)
release brake when you want to go
if anyone knows the correct procedure to engage it I'd love to have it confirmed. I'll give it a try shortly anyway.
also should note, other cars I've owned with LC won't allow it unless the gearbox oil temp is within a set range (ie not too cold or too hot) so don't try LC straight out of your garage. get the engine and box up to operating temp before trying it. it's just common sense anyway but thought it worth mentioning as people get excited and forget.
I'll also say launch control in my R35 GTR was like entering a secret code! lol. you had to work the button in order (3 of them for traction mode, gearbox mode and suspension mode), then select first gear with the paddle, then foot on brake, then floor the accelerator. it gave a nice launch at just under 5,000rpm and 0-100 in just under 3 second! pulling about 1.2G on launch too... nice.
