The Rotors?? No, they are Mercedes Benz GL450, ML63 AMG, R500 / R63 AMG which are all 5 x 112 bolt pattern and feature the correct offset to suit the standard mounting point.
The caliper mounts up to the standard mounts on the hub using a new bolts and a spacers to allow the use of a 14mm bolts.
This is a very common low cost BBK option in the USA and to some extent Europe for Mk5, Mk6 Golf and Audi S3....
The hard part is finding good used Calipers although you can buy new from ECS for US$450 each approx.
Originally Posted by
team_v
I assume these had to be re-drilled in order to fit the 5x112 bolt pattern of the Rocco?
Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
