Page 31 of 58 FirstFirst ... 21293031323341 ... LastLast
Results 301 to 310 of 576
Thread: Scirocco r mods
  1. #301
    Aug 2008
    Quote Originally Posted by RoccoR View Post
    What kit is that mate? Unusual size but big!
  2. #302
    May 2012
    Chadstone, VIC
    I bought these of Dean (owner) @ Volkspower after he had done about 3000kms on them. They pull up incredibly!!
  3. #303
    Yeah I already have the BBK cos I had them on my GTI Mk6 and now putting them on my scirocco. If they fit on the GTI with 18" rims I'm almost certain that the 19" talladegas will swallow them quite easily. The rotors are 375mm and I know they'll fit also.
    It isnt diameter you need to be worried about but spoke clearance...it is all dependent on the wheel.
    By the way.... according to the kit part number...it would appear the discs are 355mm which is a more common size..
    Good luck with it...Pics when finished would be good.
    Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
    Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
  4. #304
    May 2012
    Chadstone, VIC
    Yeah you're right they are 355mm not 375mm. Not sure where I got that from. I will definitely put up some pics when completed. 😃
  5. #305
    Looking forward to feeling the stopping power of your new brakes !
  6. #306
    Aug 2008
    This is my BBK from AP racing. Similar to the ones used on the Scirocco Cup cars.
    The 2 piece rotor weigh only 6.9 kg! (OEM 12kg)
    The 6 piston monoblock calipers, custom bracket and pad weighs 3.2kg (OEM 9kg)
    Total saving of 10kg of unsprung weight per corner!
  7. #307
    Jan 2009
    Those AP racing brakes totally look the goods.
    40kg saving is amazing
  8. #308
    Quote Originally Posted by Rev 555 View Post
    I hope you are going with ceramic pads too...no more brake dust...then...
  9. #309
    May 2012
    Chadstone, VIC
    These look awesome!! AP Racing are definitely proper track brakes.
    How much did the kit set u back including rotors.
  10. #310
    May 2012
    Chadstone, VIC
    First time I got a chance to take some pics of my recently plasti dipped Rims!! A week old now.
