Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 79
Thread: Scirocco R Modifications - RVC Info
  1. #41
    I believe City Performance in Artarmon can do this for you.
    When I do it I will try to do a detailed how to.
    I am here: http://tapatalk.com/map.php?tsvriw
    Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
    Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
  2. #42
    Jan 2012
    Great! I'll still get someone else to do it for me
    MY12 Scirocco R - slightly not stock :rolleyes:
  3. #43
    Well I am about two thirds of the way through installing the RVC and the Active Sub.
    The Camera holder is painted and the RVC cable has been run from the boot to the Radio. That part was reasonably straight forward once I had figured out where I wanted to run the cable.
    The hardest thing so far has been finding a way to run the power cable from the Battery to the Active Sub... this is not for the faint hearted...lol.
    Tomorrow I hook up the Power, Earth and Reverse sense to the RVC, remove the rear bumper, cut the hole for the camera, connect up the cables... then tackle the rest of the Sub install.
    Some pics of my poor little Roc pulled apart...
    Once it is all finished I will do a proper How To with more pics etc...
  4. #44
    Jan 2012
    North Caulfield, Victoria
    Certainly not for the faint hearted.
    Scirocco: Indium Grey, DSG, pana roof, Sat/Nav, Dynaudio, VWR springs and APR stage 1. Now sold
    Arriving April 17 Audi S3 sedan, Panther black, S-tronic, PP2, pano, matrix lights, assistance pack, 40:20:40 seats, mirror pack, light inlays
    Tiguan: Tiguan 162TSI, DAP and pano in Habanero
  5. #45
    Quote Originally Posted by Mac135 View Post
    No.. not too many people pull their brand new $60 car apart like this...
  6. #46
    May 2010
    You only paid $60 for yours? I paid a lot more than that. Let us know who your dealer is!
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
  7. #47
    Quote Originally Posted by ktrianta View Post
    Oooops.... try a touch under $60K....
  8. #48
    NT
    Yeah it takes balls alright
    All worth it once you button it all up
    Credits for doing a DIY thread as well
    WELL DONE MATE
    Quote Originally Posted by Andych View Post
  9. #49
    Sub Installation
    After a lot of head scratching and feeding of wires through the car I now have my Focal Active Sub installed and operating.
    While it is never going to be doof-doof machine (nor would I want it to be) the sub makes a definite improvement in the sound quality.
    I have trimmed back the bass on the RNS510 to about 1/3rd with Mid just over 1/2 and treble at about 3/4.
    You cant tell there is a Sub with the stereo at low (normal) level but when you crank it up the bass comes through pretty well... depending on the music it is more a feel than a sound.
    You really can't go too much past 1/2 volume as the standard speakers start to lose the plot a little once you get into the higher volume... I might have to look for some Focal splits now....
    Anyway... the install is fairly straight forward...with the hardest part being routing the power cable from the engine bay into the cabin...
    In fact routing the cables was far and away the most difficult part of the whole install. You need to pull a fair amount of interior trim away to get enough space to use a long "pull-through" to thread through and eventually run the cables from front to rear.
    The connection at the Battery is simple enough... although be careful.. the bolt they use on the battery terminal is peened over on the end so the nut doesn't come off..well it does come off but will never go back on again.... make sure you have a suitable bolt and nut.
    The power cable is run through into the area under the wiper cowl and from there through a spare grommet in the firewall.
    From there the task is getting the cable behind the dash and to drivers side footwell where it runs along the sill and into the rear quater panel and through to the boot.
    The high level connection for getting the signal through to the amp was made at the back of the Stereo
    I found the Pin-outs on Volkswagen RNS 510 pin assignments | my-gti.com
    This cable along with the remote switching cable are also run along the sill and through into the boot.
    I connected the remote switching cable to a switched power source from the fuse box situated on the drivers side...
    I was going to mount the sub on the side panel in the boot but it would have detracted from an already small boot area so I decided that it was going into the spare wheel well.
    I cut the foam holding the compressor etc with a hacksaw and cut some timber to shape... I used 2 pieces as there is a rib running through the middle of the boot floor...these were covered in black carpet... (should have used dark grey to match) and sikaflexed to the floor. Why Sikaflex? No screws needed and if I want to take it out... it is easy enough to do but it will not move under normal circumstances...
    The Sub is attached to the carpet with 4 long pieces of heavy duty Velcro and is hard to remove... but again... no screws required.
    Then it was just a matter of tidying up the wiring, testing and putting everything back together....
    I have not really fiddled too much with the settings on the amp just yet...I can maybe get it sounding a little better with some adjustment of the frequency and or phasing but at this stage I am happy that it has achieved the goal of filling out the bottom end nicely.
  10. #50
    Jan 2012
    Melbourne - South East
    Nice write-up! Ive noticed the current speakers in the car are sub par as well.
    Now to figure out what to use as replacements
    Scirocco R - Candy White, Sat Nav,tinted windows, H&R Springs, 19x9 ETA BETA Tettsut X Black rims.
    Audi S3 Sedan - Riviera Blue Exclusive paint, PP2, H&R Super Sport springs
