Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 71
Thread: Scirocco R build
  1. #61
    Oct 2019
    Mount Pleasant, Western Australia
    Thanks for the reassurance, I was hoping that would be the case.
    Bit the bullet and had the DSG tune done today. Feels a lot more refined and changes gears sensibly. It matches the power now. ECU,TCU and Suspension are now in sync.
    Waiting for the dump pipe to go to stage 2.
    thanks again.
  2. #62
    May 2019
    Quote Originally Posted by brucefil2011 View Post
    I'm undergoing a race car build. Audi 2.0tfsi Improved Production and 2lt sports sedans. So I don't have to worry about roadworthy or epa tests. I'm doing a 3 inch custom exhaust front to back which is only tube!!!
    Has been interesting reading your blog. Wish I had read it earlier as I could have offered you my high flow cat miltek system just removed from the car.
    I was really excited to find out that on the Audi s3 that the stock intercooler is so light and we'll made.
    I'm doing an E85 conversion with secret secret billet turbo build (sourced locally) so I'm really interested to see your dyno results. Unfortunately I have to run a 36mm restricted which will hold me back.
    sirrocos in my opinion are just as cool as Audi's and hair dressers don't drive them.
    Sent from my CPH1611 using Tapatalk
    G'day Bruce! If I remember correctly we chatted at Winton a month or so back, you were racing the Clio and we had our AE86.
    Nice fabrication work on the new exhaust and thanks for the offering your Milltek!
    Good luck with your build, keep me posted. E85 will certainly make a big difference.
    Current: 2013 Candy White Scirocco R (Stage 3+ 272.2kW @ wheels) 2008 Yellow MK5 GTI Pirelli (Stage 1 custom tune 191.1kW @ wheels vs. 143.3kW dead stock) 1994 R33 Skyline (627kW @ wheels)
    Past:2005 Orange RS Megane Sport Cup(165kW @ wheels) 2008 Yellow MK5 GTI Pirelli (Stage 2+ 212kW @ wheels 2009 Blue R36 Passat Wagon 2003 Silver ST246 Caldina GT-Four N
  3. #63
    May 2019
    Quote Originally Posted by WAROCCO View Post
    thanks again.
    You're most welcome. A good TCU tune makes a world of difference to the drivability of these cars.
    Which dump pipe did you choose?
  4. #64
    May 2019
    My Roc finally made it onto the dyno for a custom tuning session!
    With a fresh blend of E30 (98 + 30% E85) in the tank it managed a healthy 256kW at the front wheels. Enough power and torque that the Nankang AR-1 semi-slicks were struggling to maintain grip at 4000rpm.
    No dyno sheet of the final run as I had to leave before the tuning session ended. But here's one of the earlier runs during the middle of the session - it now makes 25kW extra in the mid-range and 17kW extra up top.
    Attached Thumbnails Attached Thumbnails Scirocco R build-74357346_723038001510002_8474232468013056000_n-jpg   Scirocco R build-76682075_723037941510008_1667592142970683392_n-jpg
  5. #65
    May 2019
    And here's the final dyno run.Scirocco R build-screenshot_20191105-132406_gallery-jpg
  6. #66
    May 2019
    The front left corner of the Rocco engine bay is a complete mess and looks ugly. So armed with a sheet of 1.0mm gloss carbon and a dremel I set out to try to improve the look.
    I also fitted the OSIR carbon door handles and DSG surround. Scirocco R build-screenshot_20191109-154651_gallery-jpg
    Scirocco R build-20191109_164149-jpg
    Scirocco R build-20191109_180943-jpg
    Scirocco R build-20191109_181028-jpg
  7. #67
    Apr 2014
    The Monash Freeway
    I like it!
    Ben
    Now: ‘19 VW Golf R, ‘15 Polo GTI
    Before: ‘06 RenaultSport Megane 225 Cup, ‘14 VW Polo GTI, ‘12 VW Golf GTI, ‘06 VW Golf GTI, ‘05 VW Golf Sportline, ‘01 Holden Astra SRi, ‘00 Nissan Pulsar SSS, ‘99 Holden Astra CD, ‘98 Nissan Pulsar SLX, ‘91 Nissan Pulsar GL with Q engine swap, ‘80 Subaru Leone
    Ben
    2015 Polo GTI & 2019 Golf R
  8. #68
    May 2019
    Quote Originally Posted by BenT View Post
    I like it!
    Ben
    Thanks Ben
  9. #69
    Oct 2019
    Apologies its been a while.
    Ordering in an APR down pipe and APR intercooler, since APR tuned, was thinking of matching the hardware with the software.
    I did read up on possibly changing the Turbo outlet pipe (aka pancake pipe) with the CTS turbo outlet pipe and also possibly replacing the throttle pipe also with CTS gear. The general discussions indicate that its neither here nor there but since the IC will be going in, it might be easier to do it at the same time.
    I read in your original post that you installed the CTS throttle pipe, did you also replace the turbo outlet pipe? Is it worth doing?
    Concerned it may not mate up to the APR IC.
    I will probably stop at stage 2 (i.e. without the HPFP). I intend to track the car and too much torque in the mid-range would be counterproductive on a track with a FWD.
  10. #70
    Oct 2019
    Quote Originally Posted by Whatsisname View Post
    WOW..... I have some work to do to make it look as good as that... Looks better than Oem.
