Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: Scirocco R build
  1. #21
    May 2019
    Scirocco R build-20190827_143108-jpg
    Scirocco R build-20190827_143052-jpg
    Current: 2013 Candy White Scirocco R (Stage 3+ 272.2kW @ wheels) 2008 Yellow MK5 GTI Pirelli (Stage 1 custom tune 191.1kW @ wheels vs. 143.3kW dead stock) 1994 R33 Skyline (627kW @ wheels)
    Past:2005 Orange RS Megane Sport Cup(165kW @ wheels) 2008 Yellow MK5 GTI Pirelli (Stage 2+ 212kW @ wheels 2009 Blue R36 Passat Wagon 2003 Silver ST246 Caldina GT-Four N
  2. #22
    Apr 2014
    The Monash Freeway
    Gonna do a dyno video?
    Ben
    Current: ‘19 VW Golf R
    Past: ‘05 RS 225 Cup
    Ben
    2015 Polo GTI & 2019 Golf R
  3. #23
    May 2019
    Quote Originally Posted by BenT View Post
    Ben
    Yes, that's the plan. Still waiting on the APR LPFP (and KWs, Milltek etc) but as soon as it arrives we'll be installing and then tuning.
  4. #24
    May 2019
    I thought why not post up some photos of the other "toy" whilst I'm waiting for the other Roc parts to arrive.
    Hopefully it's not against the rules - please let me know if it is.
    Attached Thumbnails Attached Thumbnails Scirocco R build-20180526_182947-jpg   Scirocco R build-20180526_174153-2-jpg
    Scirocco R build-20180526_174406-2-jpg
  5. #25
    Apr 2014
    The Monash Freeway
    Very nice! I’ve always had a soft spot for Skylines but never had the balls to buy one because I do too many kms and can’t afford a new one.
    Ben
    Ben
  6. #26
    May 2019
    Thanks Ben. I bought my 9/1994 model back in 1999. It had done approximately 42,000klm and has 67,000klm now. I used it as a daily for about 6 months.
    I ordered a Motec C125 for it yesterday and a set of Bosch 1650cc injectors. The current ID1050s are at their limit (mid 90s DC) and that's with base fuel pressure set at almost 58psi! The engine and supporting components are built for 1000hp territory, with the exception of the current gearbox. Boost will be increased from 29psi to 35ish.
  7. #27
    Apr 2014
    The Monash Freeway
    Awesome! I will continue to live vicariously through you. Keep up the posts and pics please.
    Ben
    Ben
  8. #28
    May 2019
    Will do. Between the two projects there should be something worth posting up on a fairly regular basis.
  9. #29
    May 2019
    Well it took a bit of mucking about but the Forge catch can kit is finally in and plumbed up. We had to remove the barbed fittings from the PVC plate and use a pair of -10 Speedflow threaded fittings and then 90' adapters stepped up to -12.
    It all fits neatly under the ECS carbon engine cover.Scirocco R build-20190830_172524-jpgScirocco R build-20190830_172825-jpg
    Scirocco R build-20190830_172653-jpg
    Attached Thumbnails Attached Thumbnails Scirocco R build-20190830_133834-jpg   Scirocco R build-20190830_133821-jpg
  10. #30
    Apr 2014
    The Monash Freeway
    Looks awesome!
    Ben
    Ben
