I purchased my MK2 GTI 1983 rocco many years ago with the intention of building a show / race car that could still be streetable and legal. This project has no real budget... and will be completed some day..
Although i have yet to complete half of the body work i have made many alterations to it allready with the aim to improve aerodynamics as much as possible whilst keeping it tasteful. I have grafted in the original bodykit pumping the guards out a little and manufactured fibre glass bumpers, mirrors and rear wing.
The 2+ litre 16v turbo engine features so far...
* JE forged pistons 83.00mm diameter 8.5:1 compression ratio.
* Pauter " X beam" connecting rods with arp bolts.
* Forged Knife Edged Crankshaft with 92.8mm stroke, enlarged oil gallerys and linished.
* Billet 4340 forged ligthened flywheel with 6 puck ceramic sprung centre single plate clutch rated 580hp
* Extensively ported and polished head, flow bench tested with new guides.
* Supertech 1mm oversize valves inconel coated on the exhaust ones.
* Supertech valve springs with titanium retainers.
* Light weight INA hydraulic lifters.
* Cat Cams turbo grind.
* Techtonics Tuning adjustable cam gear.
* Autotech light weight intermediate shaft gear.
* Aluminium light weight pulley kit for serpentine belt setup.
* ARP headstuds, main studs and flywheel bolts.
* Schrick cast alloy sump.
* vw motorsport sump windage tray.
* Custom alluminium inlet manifold with 4" plenum chamber and 2 1/4" tapered bellmouthed runners.
* Custom billet 80mm throttle body matching inlet manifold.
* Water to Air intercooler 3" inlet and outlet 1200hp flow capacity 260 by 260 by 110mm core.
* 600cc turbo logic fuel injectors.
* Custom stainless steel fuel rail.
* Bosch 910 fuel pump to 1.5 litre surge tank bosch 044 pump to fuel rail.
* Malpassi 1.5:1 adjustable rising rate fuel pressure regulator, with autometer gauge.
* 30 row oil cooler with braided hose and thermostatic flow control.
* Custom steam pipe 4 into 1 equal length exhaust manifold.
* Garrett GT30r turbo with 4" inlet 0.7 air ratio compressor housing, customised 4" outlet 0.86 air ratio exhaust housing with 38mm Tial wastegate off the side.
To buy and manufacture list...
* Aftermarket engine management purchased last as technology is allways improving.
* Manufacture hollow stainless steel intermediate shaft for weight savings.
* Full gasket kit with cometic head gasket.
* Toga high volume oil pump and racing engine bearings.
* Alluminium radiator and heat exchanger for water to air intercooler.
The drive train i am using is the 02M 6 speed quattro with haldex from the audi S3, should prove interesting to fit.... I will be cutting and raising the floor tunnel between the firewall and back seat for clearance as i also plan to fit a 4" stainless polished exhaust system.
Lots of pics coming...
