Results 1 to 10 of 463
Thread: Scirocco Picture Thread
    Feb 2010
    Quote Originally Posted by Joe7777 View Post
    If you want to plug off, can try these guys.
    https://www.bumperplugs.com/index.ph...&product_id=99
    I am about to remove the plate holder too. Had enough with it! Was just deciding between a new vinyl wrap that would cover the hole or get the plugs.
    That's a good idea. Maybe I'll save $400 and get the custom plate over the euro custom.
    The Lakin plate bracket is still a bit big for the normal custom ones (to cover up the holes I've realised).
    Stock VW Scirocco R Rising Blue
    Jan 2013
    Upper North Shore, Sydney
    Quote Originally Posted by tee_off View Post
    This is with the 2 moderate holes need to fill, ignore the middle 4 little screw holes, you should only have 2. Strongly recommend to take it down the first day perhaps before dealer fitting the plate for you. This is how this car should really look like!
    Feb 2010
    Will do. I went for the normal custom slim, ordered a few days ago!
