Results 1 to 5 of 5
Thread: Roof Rack / Roof Bars for Scirocco 2012+
    Has anyone in the forum installed roof bars on their scirocco?
    looking to see if you went Genuine or Aftermarket and your review/ ease of install/ advice.
    Quote from VW @ $631.00 and on back order from Germany (none in the country)
    Edit**
    Micks Garage from Dublin, Ireland sells aftermarket and imports to Aus from around A$210. only option I found so far
    Genuine from VW parts direct UK for $600 + shipping.
    Feb 2010
    I haven't been able to find a viable option. The Saris rear rack is recommended on the UK forums and works well but I'm scared it will damage the paintwork.
    Roofracks are possible but doesn't seem to be any solid recommendations. I saw the one from Micks but not sure if it's suitable
    Stock VW Scirocco R Rising Blue
    Jan 2019
    Quote Originally Posted by tee_off View Post
    Sent from my iPhone using Tapatalk Pro
    Very nice. look like a good fit as well.
    Where did you purchase these from and what year model have you fitted them to ?
    Many thanks in advance
    John
    Jan 2019
    John
    They’re from Micks garage
    Surprisingly quick freight AU$30
    Not expensive AU$247
    And fitted on my2012
    I did discover an odd effect at speed where the rubber contact patch flutters at resonance and I had to pop some small bits of foam tube which I’ll replace shortly wit strips of foam tape to absorb the flutter.
    Here’s the link
    Search | MicksGarage
