Any of the RNS 510 units will work in the Scirocco and will link straight up with factory bluetooth....VDUB..
Hi All,
I have try to search and seems couldn't found the answer I am looking for ...
I would like to swap out the RCD510 to a RNS510, Just wondering what version is the one that VW supplied to our Scirocco? and would the original bluetooth kit work with RNS 510?
Did any of you done this swap?
Thanks in advance.
J
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
We swapped out the RCD510 with a RNS510 in a Golf R
The most complicated task was positioning and wiring the GPS antenna
Otherwise is was a piece of cake (you need VCDS to make the coding changes of course)
Thats great... thanks for all your help!
With the Rocco's standard antenna - does that work for GPS? so no need for wiring a GPS antenna?
MY13.5 Scirocco R | Candy White | GIAC | DSG | Roof | Dynaudio |
No, you'll need a 'puck' type GPS antenna (most sellers will supply this with the RNS) or retrofit the sharkfin antenna with GPS.
The first option is the one most people take as it is very easy and provides perfectly acceptable GPS reception.
the rocco already has the shark fin antenna?
But if nav wasn't fitted from factory then it will be the antenna type without GPS.
Sent from my HTC One using Tapatalk 2
