Results 1 to 8 of 8
Thread: RNS 510 swap ... yet another thread
    Jul 2013
    Lightbulb RNS 510 swap ... yet another thread
    Hi All,
    I have try to search and seems couldn't found the answer I am looking for ...
    I would like to swap out the RCD510 to a RNS510, Just wondering what version is the one that VW supplied to our Scirocco? and would the original bluetooth kit work with RNS 510?
    Did any of you done this swap?
    Thanks in advance.
    J
    Mar 2013
    Brisbane QLD
    Any of the RNS 510 units will work in the Scirocco and will link straight up with factory bluetooth....VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2012
    Sutherland Shire, Sydney
    We swapped out the RCD510 with a RNS510 in a Golf R
    The most complicated task was positioning and wiring the GPS antenna
    Otherwise is was a piece of cake (you need VCDS to make the coding changes of course)
    Jul 2013
    Thats great... thanks for all your help!
    Apr 2012
    With the Rocco's standard antenna - does that work for GPS? so no need for wiring a GPS antenna?
    MY13.5 Scirocco R | Candy White | GIAC | DSG | Roof | Dynaudio |
    No, you'll need a 'puck' type GPS antenna (most sellers will supply this with the RNS) or retrofit the sharkfin antenna with GPS.
    The first option is the one most people take as it is very easy and provides perfectly acceptable GPS reception.
    Apr 2012
    the rocco already has the shark fin antenna?
    Re: RNS 510 swap ... yet another thread
    But if nav wasn't fitted from factory then it will be the antenna type without GPS.
    Sent from my HTC One using Tapatalk 2
