Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 99
Thread: Problems With your new Scirocco...
    Jan 2012
    North Caulfield, Victoria
    Quote Originally Posted by octagon View Post
    I have an issue with the dsg box. It changes up to 6th so quick that in traffic around 60kph it drones too much and it doesn't sound right, I'll get that looked at too when I can get back to the dealer
    That is definitely the way the DSG behaves in auto (D).
    My question is:
    Why are you driving in D in the first place? Paddles 'n stick are much, much more fun.
    Scirocco: Indium Grey, DSG, pana roof, Sat/Nav, Dynaudio, VWR springs and APR stage 1. Now sold
    Arriving April 17 Audi S3 sedan, Panther black, S-tronic, PP2, pano, matrix lights, assistance pack, 40:20:40 seats, mirror pack, light inlays
    Tiguan: Tiguan 162TSI, DAP and pano in Habanero
    Quote Originally Posted by why_999 View Post
    Fourth visit
    - Engine making a weird nosie/rattle when it hits 2K RPM, just before the turbo whistle.. and still at the dealership and they have no idea whats going on, they can hear the rattle but no clue.
    Good news is that its not from the engine...
    It was the wiper arm. So now a new arm is getting sent to the dealer to be replaced..
    Whats up with these wipers VW are using...??
    Jan 2010
    UK Cheshire
    The arm problem isn' t usual but has happened before in Europe. The blade issue is, and its due to plastic wiper carrier collapsing and the rubber being softer. This is to lower the noise level while sweeping the screen. So the rubber blade distorts too much causing smear.
    And if its not that, then there is the little minute blobs of windscreen glue that get massaged out into broad thin glue patches that cause smear patch areas from the blades continually passing over the glue over a period of use (chemical removal for this - adhesive is Polyurethane based.).
    Blades, I personally had fitted Jetta blades & carriers as the alternative on the front and have had no problem since. Parts are: wiper blades & carriers VW Part No. 5K2 955 426 - driver's side, 5K2 955 425 - passenger side. Done as a warranty claim, VW know this solution. A bit noisey for the first hour of operation as the rubber blade beds in, but after that, no problems at all. First set of Jetta lasted 17 months, just fitted my second set on Jan 1st 2012. About normal length of time for my VW cars over the years as the daily driver always sits outside in the sun. (Rear lasted 27 months - rear has no problems.)
    Also treat the windscreen with Rain-X fairly regularly. That helps a lot.
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
    Jan 2012
    N/A
    I have problem with the driver side window not going down some times if I push both window buttons down at the same time. Some times it works, if it doesn't work I just have to push it down again.
    Some times my mirrors don't fold back out for 30 seconds or so. No idea why.
    Jan 2010
    UK Cheshire
    Quote Originally Posted by preeman View Post
    How are you using the car? There can be problems when the battery voltage level gets lower through infrequent use. Door controller problem firmware has been sorted at the factory for a long time, so it can't be that. (Door controllers have control of the windows & folding mirrors.)
    There is a bulletin on the folding delay specifically that you could discuss with the dealers.
    TPI 2025610/02 - Service info - electrics - door mirrors fold sporadically with delay - 23May2011.
    Problem: The door mirrors sporadically fold with a delay upto 15 seconds
    Technical Background: Incorrect Door Controllers fitted.
    Measure (rectification): None.
    Customer Information:
    How does it occur?: During dimming of lights in the mirrors, the folding door mirrors can be delayed for upto 15 seconds.
    How can the complaint be prevented?: By waiting till the dimming is completed. This normally happens about 2 seconds after switching on the ignition.
    Jan 2012
    N/A
    Quote Originally Posted by RW1 View Post
    The car is my daily drive for work, I am getting about 80KM per day. The windows can happen at any time, I might have been driving for 20 minutes when I decide to put the windows down. I will take it to the dealer and see what they say.
    Thanks for the info on the folding delay.
    Feb 2010
    I was dreading this thread.
    Does this mean I will have to buy (and learn to drive) a manual to be safe?
    Stock VW Scirocco R Rising Blue
    Jan 2012
    To be safe in what way?
    Quote Originally Posted by tee_off View Post
    well i don't see why. No one has had an issue with their DSG gearbox... yet.
    Sent from my GT-I9100 using Tapatalk
    May 2010
    Yeah I agree. The DSG has gone through a number of iterations since it's original release. No one would call it perfect, but it's a pretty damn good, dependable gearbox.
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
