Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Oil Temperature and Synthetic Oils
  1. #41
    Jan 2012
    N/A
    @brad
    This is what is listed in the Manual and similarly in the Supplement for the Oil table.
    They don't list what to use or am I reading it wrong?
  2. #42
    Jan 2012
    N/A
    @brad
    And you appear to be under the impression that VW / dealer are the same entity. They are not.
    I understand and appreciate the legalities of the separation of entities.
    From a consumer point of view and what the Department of Fair Trading see, they are an authorised representatives and I do not need to view them as individuals.
    As it was said on this thread (I think) work done/parts supplied under warranty by the dealer is backed/supported/funded/authorised by VW DSS ticket.
  3. #43
    Jan 2012
    N/A
    @Transporter
    I am fine with this thread and I am taking corrective steps as required. Such as checking oil and buying top-up oil for future use.
    Everyone has a point of view and their expertise, I just need to work out what I will do with it.
  4. #44
    Jan 2012
    N/A
    And I now have Oil!
    I got the Service Department to top this up for me. I have just gotten home and checked the level again here and it is now past the Arrow point for Max and well up towards the end of the word Max.
    It seems like they have put too much oil in? The manual says not to go past the top mark (Arrow point).
    Should I just leave it now?
  5. #45
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by preeman View Post
    The VW 502/504/507 oil specifications are what you need
    Just purchase any oil that is approved/certified to that specification level
    Penrite oils are a good place to start
    Pentrite Enviro+ VW 504/507
  6. #46
    Erskineville, NSW
    @brad
    Badly done Cherman chart. The dash means "äs above". The letter is referring to the emissions regime & they didn't know what it was. That's my take on it.
    You're on 12m/15k service intervals. For petrol engines use 502.00. For diesels use 507.00.
    If you are on LongLife (variable time & distance up to 2yrs/30,000km) you use 504.00 for petrol or 507.00 for diesels.
    What it doesn't point out (it's in another para) is that for severe service (examples are given) you should reduce change intervals. Most folk use 504.00/507.00 on the 15k/12m regime (all 504.00 oils have 507.00 certification as well) and this counteracts the severe service issues. 502.00 is fine for top-ups & readily available.
    The oil Martin points out is great & cheap - ~$70/5L. Shell Helix Ultra Extra is also 504.00.
  7. #47
    Pacific Paradise QLD
    Yes I use Penrite Enviro+ in both cars
    ALL Australian VW are on Time or Distance servicing.
    The oil recommended is the minimum spec and the higher spec is useable as well.
    It SHOULD be VW approved and in the lubricant section there is a list of APPROVED oils listed
    The -a refers to the note under the chart as does the -b
    If in doubt use the 504/507 APPROVED oil
    It might be expensive but its a lot cheaper than a new engine.
