Or maybe it was changed for a single mass by the previous owner?
That'll probably be the dual mass flywheel if it changes with clutch pedal.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
They’re definitely not a quiet engine but as above recommend replacing the fuel pump cam follower as preventative measure.
Ha
Still haven’t found a workshop that will do the HIGJ Pressure Fuel Pump cam follower for less than $500
But I did discover my bonnet strut pivot end has lost its rubber grommet and rattles !
Anyone else got a pic of what the bonnet strut pivot Gromet should look like ?
Sent from my iPhone using Tapatalk Pro
Yes I see a few posts saying easy.
As I understand it you remove the lines and the pump and replace the follower. Seems straight forward.
Of course that means a gasket and making sure the fuel lines are depressurised and then bled free of air.
What could possibly go wrong with a HIGH pressure fuel pump ?
DOES ANY ONE HAVE Actual experience with this. I’d love to know what to buy ahead of doing it. I really don’t want to get stuck with a leaky gasket.
I already learnt that just ignoring the little o ring on the dipstick has dire consequences.
TIA
Follow the first 12 steps in the DIY I did a few years back. I never changed the o ring as my car only had about 10,000km on it at the time, but it would probably be a good idea to replace the o ring now that these cars are getting older. Autotech HPFP Upgrade full DIY guide with pics
VAGParts in Sydney would be able to source you the genuine o ring. Volkswagen Scirocco Parts, VW Scirocco Car & Auto Parts
– VAGPARTS Australia
